Tolerance Modeling
Tolerance Modeling
Christoph_360
Tolerance Modeling
Christoph_360
Hello everyone
Is there a possibility in Fusion to provide dimensions with tolerances (e.g. 90-h9 or 90 -0.1/-0.2) and to set the model to nominal dimension or center tolerance.
Mfg
Christoph
g-andresen
The tolerance specifications are added to the drawing.
günther
Christoph_360
Hello
It's a pity, then there is only the possibility to control the nominal dimension or center dimension model via one parameter.
Center Dimension Model
Mfg
Christoph
TheCADWhisperer
@Christoph_360
You can set Tolerances in Autodesk Inventor Professional for sketch and feature dimensions.
Then evaluate at Min/Max Median/Nominal...
Inventor 2024 Help | To Edit Tolerance for Individual Dimensions | Autodesk
Taking a step further...
And Parametric Dimension control in FEA Analysis...
Where you can set ranges, steps - all sorts of control and then Promote to the model when the analysis is complete.
Inventor 2024 Help | Work with Parametric Studies | Autodesk
Christoph_360
Hello
Yes, thank you very much for the helpful information.
Yes, this is the function to solve tolerance modeling optimally, especially in the cam area for turn-milled parts, this is an important function.
But Fusion offers an outstanding price/performance ratio and so it's great that you can solve this task in Fusion as well.
Mfg
Christoph
