TO SHOW THE TEXT IN HIDDEN LINE
atdemo2019
atdemo2019
 Hi Guys, I have an issue while doing drafting. I need to show the hidden lines from the back side view.
    When Iam doing this, the text appears as solid line.
    I want to show it as dotted lines.
    How to do this?
Thanks in advance....
Marco.Takx
Hi @atdemo2019,
Can you please share your file?
I've placed text on a test block and extruded it 0,001 mm into the surface.
See my result.
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
liang_chen
Maybe the size of model is small, and text geometies are smaller than the length of hidden line definition. Please enlarge the scale of drawing view and check if the text will display as the hidden line, showng as the attached video. Thanks
Fred Chen
SQA Engineer
Quality Assurance Team
Autodesk, Inc.
atdemo2019
Hi @Marco.Takx , thanks for the reply ...... I got the result by increasing scale size.
atdemo2019
Hi @liang_chen , Thanks for the brief video, I got the result now.
