Title Block Saving
Title Block Saving
jasonhomrighaus
Title Block Saving
jasonhomrighaus
Is there a way to store a title block in fusion so that it comes up as an option when creating a new set of drawings? Im hoping it can be stored so that any time I create a new drawing I could go to sheet settings and just choose it without having to import it every time.
I know I can use a template but that is a pain and requires a bunch of extra steps and creating templates anywhere you might want to make drawings.
bwalker145
Not sure I understand why you don't want to use templates, sounds like exactly what you're looking for?
You just create it once (I created one for each of the sheet sizes I may use), and then just select the template whenever you're creating a new drawing.
jasonhomrighaus
To use a template you have to copy it into the folder where you want to make a drawing.
For most designs I have between 8 and 10 folders where I organize the various components(flat parts, machined parts, hardware, etc)
That’s 8 to 10 times I need to copy the template into each folder before I can access the template. And as you said if I need a different size sheet then I need yet another template.
I’d like to have a central location where I can store a title block or a template and be able to access anywhere I need it.
bwalker145
Hmm, that doesn't sound right, you shouldn't have to drop them into the same folder to use.
I have one folder where I store drawing templates, and am able to access the templates for any design/project without issue (even projects with sub-folders to organize components, similar to you).
