Title Block Edit
Title Block Edit
Title Block Edit
Hi, I've only recently really played with the title block feature.  Is there anyway of editing the headings that are in the default title block without having to build one from scratch?
cheers
HughesTooling
Are you trying to modify in a drawing or in a template? If you double click on the title block you get a dialog with the option to edit, if you have a drawing with the Fusion default you'll be prompted to add a title block, click OK and an editable version of the default will be created. Similar will happen if you're editing\creating a template using, New Drawing - New Drawing Template from the file menu.
If you have a drawing with a title block you want to reuse, just select Save As from the file menu and select and select drawing template for the type.
Mark
Mark Hughes
Owner, Hughes Tooling
thanks for the reply, exactly what i was after.
