Fusion 360 does not have the capability of scaling an imported SVG to exact dimensions. You can only do proportional scaling during the import.
This is a work around. Simply import the SVG. Unlock it. Then use the dimensional tool to specify height, width or even a single element.
Everything will rescale proportionally to that dimension. There is a limit to this technique until the sketch breaks. (due to SVG precision)
Edit for clarity:
Note: You must have "Scale entire sketch at first dimension" enabled in design preferences. If you have an already dimensioned sketch that you want to import the SVG then create a new sketch on the same plane. Import the SVG. Dimension it to scale it. Copy the profile. Simply paste it to the targeted sketch. Then you can disable the preference.
3 examples demonstrated in this.
It is such a simple and implied (duh -really!) technique but never seen it demonstrated on Youtube.
Have not tried this with DXF imports. Should work though.
Youtube Demo
