- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello All,
I have a timeline problem:
I made a complicated device formed by two almost identical, mirrored pieces.
-I made one piece as a component with all its internal structures. this is the first working part.
-I copied that component and did 'paste new', so that not all changes from the first component will affect the second component as well.
-I switched to the new component as work piece and made some outer modifications, and saw that i have to redo the internals as well. since the internal structures were first made on the first component, i switched back to the first component as a work piece, changed some stuff there, and noticed that they were not changed in the second component.
-WHY?
i made those internal changes BEFORE i copied the component. so the new Changes made before the copying and paste new should be copied as well.
...or not?
can somebody enlighten me here?
Thanks in advance to this forum. This help is always appreciated.
