Thread Trouble
Thread Trouble
Compwiz1
Message 1 of 9
Thread Trouble
Compwiz1
I am having the hardest time getting these threads to work. I have a two part model that I want to be flush with one another when the pieces are screwed together. I have threads on both parts but the treads just don't seem to match up. Any idea why this might be happening and what I can do to fix it?
ThreadsThreadshole thread configurationhole thread configurationthreads3.jpg
Replies (8)
Message 2 of 9
jhackney1972
Please attach your model so the forum users can assist you using your exact model.
John Hackney, Retired
Message 3 of 9
wmhazzard
If you model the two components together and then add the threads, they should line up. If not attach an f3d file of your model.
Message 4 of 9
jhackney1972
I just noticed this is your first post.  If you do not know how to attach you model do this.  Open your model in Fusion 360, select the File menu, then Export and save the model to your hard drive.  Then use the Attachment section of a forum post to attach the file.
Message 5 of 9
Compwiz1
Thanks. I attached my model. There are several sections to this that are supposed to screw together. I'm pretty new to modeling in Fusion360 so the model may not be the cleanest, any help would be great!
Message 6 of 9
wmhazzard
For your model, leaving the sleeve solid and doing a combine cut with the switch will align the two threads but you have to manually offset the female threads to allow for clearance. I used 0.1 mm in the attached file and you may need more if you are 3d printing this.
Message 7 of 9
Compwiz1
That's awesome, thanks! Just curious, why did you give so much clearance at the bottom base?
Message 8 of 9
wmhazzard
It is standard practice to leave clearance at the bottom to allow for imperfect threads. If it was machined you would have at least two or three revolutions of imperfect threads even with a bottoming tap so you would have even more clearance than the 1 mm that I left.
Message 9 of 9
Compwiz1
Ah ok, makes sense, thanks. My background is in 3D modeling for gaming/animation so I'm not used to thinking of things from a real world manufacturing perspective.
