Thread Dimensions
Thread Dimensions
Message 1 of 11
Thread Dimensions
I am wanting to model a 4 1/16 -12 thread on a part I am working on, however no matter what size I model my ID hole it will not give me an option past 4.0 diameter.  I know I am being picky as it is not needed for me to do the actual part.  I just am wondering if there is a way to override the default max of 4.0.  I do a few custom threads that are non standard and wondering if I can model them.
Replies (10)
Message 2 of 11
SaeedHamza
You can scale the thread after applying it
If you can share a picture of what you're after, I'll show you how to do it
Regards
Saeed Hamza
Message 3 of 11
Its a 4 & 1/16th -12 thread.  I have the minor set to my drawing dimension of 3.977.
Message 4 of 11
PhilProcarioJr
@Anonymous
One thing you can do is create a custom thread .xml file.
It was posted before:
There is a way to accomplish your purpose:
1. go to thread data folder--> [Fusion install path]\Fusion\Server\Fusion\Configuration\ThreadData
2. make a copy of the thread family that you want to customize, for instance: "ACMEScrewThreads.xml" copy to "MyThread.xml"
3. open the "MyThread.xml", change the "<Name>ACME Screw Threads</Name>" to "<Name>My Customize Threads</Name>"(any name is ok, just make sure it is unique)
4. define thread shape for your customize thread: add "<ThreadForm>0</ThreadForm>" under the <ThreadType>,
        0----trapezoid; 1----sharp; 5----square; 7-----withworth
     if you don't add this, default shape is trapezoid
5. now you can customize anything, including the pitch/diameters...
Please note:
  •  If you create a thread by your customize file, and save the f3d document, and open it on other machine, when other people try edit the thread, he will get an error message "...the current thread family has no suitble type..."
  • If you directly change a standard thread type, and create a thread save to f3d document, when other people open it on their machine, recompue or edit the thread will get back to standard shape.
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 5 of 11
Not the greatest coder, where do I add that in? anywhere or at the top, or bottom?
Message 6 of 11
PhilProcarioJr
@Anonymous
Copy this file into your ThreadData folder and it should show up in your list after restarting Fusion.
Phil Procario Jr.
Message 7 of 11
PhilProcarioJr
@Anonymous
Here it is showing internal threads.
Phil Procario Jr.
Message 8 of 11
PhilProcarioJr
@Anonymous
Double check my numbers as I did this really quickly and could have missed something....Smiley Wink
Phil Procario Jr.
Message 9 of 11
Awesome, thank you.  This will allow me to model my weird custom threads I get.  Thank you much. I appreciate it
Message 10 of 11
PhilProcarioJr
@Anonymous
Make sure you keep a copy of that file and any changes you make to it in a safe place other then the ThreadData folder for 2 reasons...
1) In case anyone else wants to open your file they will need it...
2) Because if I remember correctly you will need to copy it back into the ThreadData folder if you reinstall Fusion or if it is updated.
Phil Procario Jr.
Message 11 of 11
good to know. I will save a copy to my desktop. Thank you I appreciate it
