Thin Extrude - Draft
prasoonFML6E
Observer Observer
Message 1 of 15
prasoonFML6E
Observer
Observer
When using a thin extrusion to create a reinforcing rib on a long, slender plastic part, the draft angle applied during the extrusion process is only affecting one side of the rib. How can I ensure that both sides of the rib are drafted correctly?
Below are some images that show a simplified representation of what I'm experiencing.
F360 RIB ISSUE 1.pngF360 RIB ISSUE 2.pngF360 RIB ISSUE 3.PNGF360 RIB ISSUE 4.png
Replies (14)
Message 2 of 15
davebYYPCU
Try setting the rib as symmetric, maybe the draft will be applied, both sides in this scenario.
Might help…..
Message 3 of 15
g-andresen
This is not a draft but a rotation.
Günther
Message 4 of 15
g-andresen
first create a thin extrusion and then the taper with the draft tool
(view in My Videos)
If I remember correctly, the taper option for thin extrusions has always resulted in a sloping extrusion and not a tapering of the profile.
@Phil.E
Am I seeing this correctly?
günther
Message 5 of 15
Phil.E
Yes, but I have questions. I asked the modeling developers to take a look, because I fail to see the connection between taper for regular extrude and just leaning the thin extrude in a direction using "taper", which is more like "send this off along a vector" but not "taper".
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 6 of 15
HughesTooling
@Phil.E As a mould maker I lean towards (pardon the pun😄) having a drafted (Tapered) result rather than an angled web. Might be a case for a checkbox to have draft or angled extrusion?
Mark Hughes
Owner, Hughes Tooling
Message 7 of 15
Phil.E
@HughesTooling
Agreed.
Here's an example where draft is critical, and it covers 100% of the backside surfaces of a design.
A design from a former life. Plastic in-wall speaker frame. Look at all the thin extrude.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 8 of 15
g-andresen
Another problem is that with thin extrusions the connection to the base is lost on one side when the taper option is active.
günther
Message 9 of 15
Phil.E
Yes that was easy to spot. I included it in the bug report. (FUS-174238)
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 10 of 15
prasoonFML6E
Observer
Observer
I tried setting it symmetrically, but it doesn't help.
Message 11 of 15
prasoonFML6E
Observer
Observer
Yes this solution do work, but i was trying to avoid clicking so many surfaces and apply the draft individually as in my original file there are around 170+ faces.
Message 12 of 15
prasoonFML6E
Observer
Observer
Yes. It's a bug. 😶
Message 13 of 15
g-andresen
Try Window selection
günther
Message 14 of 15
Phil.E
@g-andresen I tried some other methods. I think Paint and Freeform selection style might be helpful if nearly every face is a draft target, they are a little more precise than window select.
Window selection tip: Use left to right direction to achieve "only objects entirely within selection window"
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 15 of 15
g-andresen
Thanks for the hint
Günther
