Thickness per Face?
Thickness per Face?
Message 1 of 8
Thickness per Face?
I have the body that I want modeled in the the Sculpt Environment and depending on the face I want a different thickness.
Is there a way to use the thicken tool for individual faces on a single body? Or a good work around?
-SarahRose
Replies (7)
Message 2 of 8
Bud_Schroeder_ADESK
Hi SarahRose,
Thanks for posting to the forums, and welcome. Can you tell us what product you are using? Is this a question about Fusion 360? Let us know and we can try and get you pointed to the right location for help.
Bud Schroeder
AutoCAD Customer Council Beta Programs
Autodesk Inc.
Join the AutoCAD Customer Council Beta Program.
Message 3 of 8
Yes, This is Fusion 360
Message 4 of 8
Bud_Schroeder_ADESK
Thanks for letting us know and I'll move this message to the Fusion forum.
Bud Schroeder
Autodesk Inc.
Message 5 of 8
TrippyLighting
Welcome to the Fuiosn 360 Forum!
The thicken command does not provide an option to thicken individual faces.
Could you post a screenshot or share your design so we have a better idea what you are treing to achieve ?
Message 6 of 8
My goal is to have the entire body have a thickness of 5mm and the blue section a thickness of 7mm, while maintaining direct modeling capabilities
Message 7 of 8
TrippyLighting
Not knowing what the desired overall end result of your desing is it is hard to give a recommendation and the following might not address what you need.
However, there is not need to model this siple geometric shape in the T-Spline environment. This is much simpler to do in the Model environment and there can be done either in parametric or direct modeling mode.
T-Spline modeing is better used for smooth organinc forms.
Message 8 of 8
I'm not at liberty to share the exact file. I've used the direct modeling capabilities to create a cylinder like shape. Most of the shape needs to have a uniform thickness with several faces at a different thickness.
