I read my post once again and it could be very unclear 🙂
I do not think that they are a larger gap which has lower resistance than a smaller one, I will probably need to look into some book abou the heat and mass transfer, but that is a difference between the solid and fluid thermal resistance. Solidbody thermal resistance is a linear function of the thickness ( standard cartesian coordinates system) with the fluid gap thermal resistance does not increase that much with a thickness of that gap. Two times larger fluid gap could have almost the same thermal resistance as the smaller one. That is what I was meaning by:
"do not threaten the fluid as solid material"
I will also add some explanation about the difference between the results, after reading what I wrote once again I have a problem understanding what I wrote 😛
In the first scenario, you applied thermal resistance as:
R=AirConductivity thermal resistance
In the second scenario you probably want to apply:
R= Convection Resistance Hot Side+AirConductivity thermal resistance(by adding air body)+Convection Resistance Cold side
So the thermal resistance is much higher than in the first scenario.
The AirConductivity thermal resistance is the same in both scenarios just applied in a different way.
BTW the convection resistance should be applied as a contact between the fluid and solid body.
So, you mean the two parts should be in contact like in the first simulation and I should adjust the thermal conductance of the contact?
Exactly, the thermal gap has its own resistance depending on the depth and location of the gravity vector so there is no reason to add the air body to the solid body simulation.
BR
Karol
