I am working on a model that has a wooden surface that will have text printed on it when being manufactured. What is the best way to achieve this? I have tried the following workflow but it is very tedious as there is a good bit of text i need to add and was thinking i must be missing an easier way to do it:
Use the text tool to place text on component face -> Extrude the text as a new component by a small distance -> Then to change the colour of the text i need to select the body of each single text character and go into the Appearance settings
Is it possible to change the Text tool font colour. Also, would this appear in renders as it is just a sketch?
Thanks!
