Text as Sketch help
- Mute
- Permalink
- Report
I was really excited to see the new Text as Sketch command in the latest update, this was a HUGE hole in Fusion 360 from my point-of-view. However, I found it very confusing to actually use so I thought I would add a quick note here to aid others with the same problem....
I was expecting the Text command to work like the Circle and other Sketch commands - after all it is on the same menu! It does, in that you create flat text on a surface just as you would a circle. However once it is created it is not treated the same as a circle or other sketch element. You cannot Push/Pull it into a solid as you would to turn a circle into a cylinder. Instead you need to go to the Create commands. Instead of using Push/Pull you must Extrude the text. This will give the same results as pulling a circle. You can also use the Revolve and Sweep for some interesting results!
