@SaeedHamza
Technically speaking you are right.
However:
The process you use with TS takes more time than it should
If you later then need to adjust the path the wire flows along you will add extra time sculpting the change by hand
while with the correct tool option it would be a mouse click only.
I think @copypastestd and @Anonymous are looking for efficient tools less time consuming alternatives.
Spirals are really had to make and adjust smoothly by hand.
When I do wires I use a spiral tool to make the helix and the loft along the path in my other apps.
This is all surface / nurbs based and fast.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
