I have a basic cone shape (see attachment) that I want to tile to give the look of a castle roof. I've attached a sample picture of what I'm going for (but have a lot of flexibility).
My original hope was to use a combination of a rectangular pattern and the emboss command. Unfortunately, I haven't had much luck with that. A usually have a mixture of the following issues:
1. I sometimes get errors from the emboss command about the surface being two discontinuous surfaces.
2. When it does work, it doesn't want to wrap the very tip of the cone. When I move the sketch to be emobossed to the peak of the cone, it begins to wrap around on itself and gives errors about overlap
3. If I try and emboss just a single horizontal line of tiles at a time, the tiles lay flat against the cone and thus aren't horizontal lines anymore but rather angle downward since the embossed sketch needs to lay flat against the curved surface.
My backup plan is to just slice up the cone horizontally and then chamfer those split up surfaces. This gives me a nice look for the horizontal lines. Unfortunately, I have no idea how to split up the cone vertically (and all flowing outward from the spire).
Any tips would be very much appreciated! Thanks!
