Technical Drawings in mm
heyarn
heyarn
Hi Folks!
I'm trying to use the drawings, but it's set to inches.. Under the drawings settings/preferences, I'm unable to select mm. Is there a right way to do this?
Thanks!! 🙂
michallach81
Hi, you need change units in Fusion preferences, not in drawing settings. Preferences you will find if you extract tab with your name on it (top right corner).
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
ADSKDJW4
Hello heyarn,
Just adding screen shots that the initial reply talks of, if this helps.
Then make modification here,
This should correct what your looking to do. Please reply to post if it does not.
Best Regards,
Don Warner
heyarn
Thanks guys! I got it to work. I could definitely use more skills in making these tech drawings. Are there any tutorials I could follow that you'd recommend? (cant seem to find any on youtube)
jeremy.goldman
Hi Heyarn, thanks for your interest.
It's a little out of date, but the Fusion 101 Trainings are a nice walk-through for all of the Fusion workspaces, including Drawings. Check back soon, because the whole Fusion 101 is getting a massive overhaul at the next Fusion release.
Fusion 101 training
http://help.autodesk.com/cloudhelp/ENU/Fusion-GetStarted/files/GUID-CC9A8E39-356C-43EA-9EDD-0E9C1321...
https://www.youtube.com/playlist?list=PLmA_xUT-8UlJpYbha60oAQMxFlBY371oZ
And if you haven't seem them already, check out these 2D Drawing videos on the Learning & Resources site:
Generate 2D Drawings from Fusion 360 Models
http://help.autodesk.com/cloudhelp/ENU/Fusion-Fabrication/files/GUID-A476C8D8-1EE2-4AA1-9A97-88DB74A...
Add Annotations to the Drawing
http://help.autodesk.com/cloudhelp/ENU/Fusion-Fabrication/files/GUID-80E85161-D842-4779-8596-4C2ECF0...
Section Views
http://help.autodesk.com/cloudhelp/ENU/Fusion-Fabrication/files/GUID-02A9A02A-B020-4BC3-A818-88BE5DF...
Hope this helps!
Jeremy
Jeremy Goldman
Senior Learning Content Developer, AutoCAD
ADSKDJW4
Hello heyarn,
Fusion follows quicker cycles for product update it’s challenging to provide videos showing all content. Another option from the last useful reply post with links would be to check out https://screencast.autodesk.com/ and set the product to Fusion 360 All Years. The videos there might give you some specifics on workflows.
Best Regards,
Don Warner
