Technical drawing issue : view disappearing
Hi all,
I am supposed to do a technical drawing for one of my assembly. But every time I try to put a view, it disappears and a red square appears on the corner of the sheet. I made many trials, full assembly or not, different sheet sizes, different scales... but it always ends in the same way. Do you have any idea on what is going on ?
Here are Before and After validating the view screenshots :
krithika.sundararajan
Hi mathildeWQU3Z,
Sorry to hear you are having problems creating drawings. Just to confirm - is this happening for the specific design only or for drawings created from all designs?
We learnt of a similar problem with a model earlier and we have a fix which will be included in the upcoming update on June 22. Would you mind attaching your design file so we can confirm that the problem will be fixed for you? If you would like to share it privately instead, you could send an email to: krithika dot sundararajan at autodesk dot com
Krithika
Thank you for your help. I have just sent it by mail, to respect the confidential aspect of my product.
Thanks, Mathilde. As I shared with you by email, this issue should be fixed in the update next week. Thank you for your patience.
Krithika
