Tapered Extrude Problem
I've probably been working on this extrude problem for several hours now. I'm starting to worry I'm not going to come up with a valid tapered extrude. I know imported dxf files can be problematic in Fusion 360 but I just dont' have the luxury of this information coming to me from Fusion 360 natively. I need to put a 4.36 degree tapered extrude on the sides of the trench that makes the images. Can anyone tell me what I'm doing wrong. I know if one tapered wall face is "consumed" by another before it reaches the floor of the trench it will cause an invalid operation but I can't see where this is happening here. I can get the extrude to work with a taper of 3 degrees but 4.36 is not working. I'm burning a lot of brain cells on this one. The outline was originally made in Rhino. I've take the dxf export and opened it in Autocad to sort out some issues. I've tried converting the polyline to arcs. The answer might lies in one of these operations but nothing I've tried so far seems to make it produce. Of note: When I have excluded the bear from the extrude operation it works! Any help is greatly appreciated.
Mike
