So I understand a CNC machine typically uses the right hand rule for the coordinates and tool direction. I have an XYZ gantry router so the 0,0,0 is the left lower corner. If I tile on this machine the long dimension is along the Y axis.
In AutoCad typically the long dimension of a part, 4x8 foot plywood sheet in this case is along the CAD X axis.
Is it as simple as creating an offset with 90 degree rotation? Or do you rotate and shift the CAD file prior to generating G-code?
