T-Spline surface smoothing
Message 1 of 49
I like the sculpting features in Fusion a lot, but anyway after pushing pulling edges and points and surfaces it very often happens that there are ripples, nudges, unexpected folds in the surface, like in the attached image. The fold shown is not on a specific edge or point I could grab and pull out. I have also no clue where it came from. I assume (simply said) I was pulling somewhere and did not notice that I created that fold somewhere else. Here comes my question: Where do I find the tool to "smooth", "Iron" or "sandpaper" this fold. And if it exists, where can I limit the area of such a tool ? I know that with a bunch of clicks here and pulls there I can probably smooth this one. But I am searching for a simple way.
Replies (48)
Message 2 of 49
PhilProcarioJr
@Anonymous
There really isn't an easy tool for this....Under utilities you have make uniform but the rarely works.
one of the best ways to work with T-Splines is to apply a curvature map to the T-Spline so you can fix problems like this and to keep you from creating bad geometry.
I would have to see your model to know the actual problem.
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 3 of 49
I had the chance to discuss this yesterday with a developer from Fusion in front of my computer. Looks like there is no solution. But if so, this means.....redraw. I can't believe I am the only one having this issue. Thanks for you help anyway 🙂
Message 4 of 49
cekuhnen
@Anonymous
As @PhilProcarioJr it comes down to topology. I would not use any smooth tool here since it is a low res poly body but rather look at the topology and even out the position
of the CVs.
This might be harder to do when in smooth view.
Go to Utilities and inside Display Mode switch between box and smooth.
You can also press CRTL 1 2 and 3
Screen Shot 2017-05-17 at 8.44.05 AM.pngScreen Shot 2017-05-17 at 8.43.56 AM.png
Look here:
All looks smooth and fine:
Screen Shot 2017-05-17 at 8.42.28 AM.pngScreen Shot 2017-05-17 at 8.42.33 AM.png
to sharpen or smooth transitions key is to bring edges closer together or further apart
Screen Shot 2017-05-17 at 8.42.58 AM.pngScreen Shot 2017-05-17 at 8.43.02 AM.png
When however I move the edges beyond the neighbor edge I can start to crease / self intersect the surface too much
Screen Shot 2017-05-17 at 8.43.28 AM.pngScreen Shot 2017-05-17 at 8.43.36 AM.png
based on the image you gave us I think you moved edges too far - just move them back
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Message 5 of 49
SaeedHamza
Could you please attach a f3d file
Regards, Saeed
Saeed Hamza
Message 6 of 49
Sure, just ran through the newest update:-)
Message 7 of 49
cekuhnen
@Anonymous
the export file is empty
Claas Kuhnen
Message 8 of 49
next try 🙂
Message 9 of 49
SaeedHamza
your problem is that this edge ( check picture ) is disturbing the smoothness of your surface, so delete it and you're good
after all it's not about smoothing the surface in sculpt environment, it's about knowing how to manipulate vertices, edges and faces
Regards, Saeed
Saeed Hamza
Message 10 of 49
cekuhnen
@SaeedHamza @Anonymous
Not only that but I think the topology is also too dense - simplify it while maintaining the desired shape
and while TS allows it I would advice against NGons
Claas Kuhnen
Message 11 of 49
SaeedHamza
Yes you're right, too many faces can cause losing control of the shape being created 🙂
Saeed Hamza
Message 12 of 49
PhilProcarioJr
@Anonymous
There are times when N-Gons are fine, but this is not one of them. You should confine the use of N-Gons to completely flat surfaces only.
Phil Procario Jr.
Message 13 of 49
SaeedHamza
What do you guys mean by N-Gons exactly? are you referring to vertices?
Regards, Saeed
Saeed Hamza
Message 14 of 49
cekuhnen
@PhilProcarioJr Not necessarily. I should also have been more clear. NGONs in surfaces can work pretty well. However NGONs at surface edges can be disruptive.
Claas Kuhnen
Message 15 of 49
PhilProcarioJr
@SaeedHamza
More then 4 sided patches.
@cekuhnen
I still stand by what I said, in over 2000 hours of working with T-splines I have found that you should keep them on flat surfaces only. Using them on any surface with curvature causes you to lose the ability to edit them without trashing your surface. It's just asking for trouble.
Phil Procario Jr.
Message 16 of 49
So, now we are back from where the thread started. There are a bunch of ways to screw it up. But it exists no solution (let's call it UX). I have removed a lot of edges, simplified my model. But I still don't get the mess out. See attachment. Or asking my question again: Is there a tool to "smooth", "sandpaper" or however you call it that helps me getting out of the issue ? 🙂
If not, I will start this from scratch.
Anyway.... your comments helped me a lot guys !!!
Message 17 of 49
TrippyLighting
A trick that @PhilProcarioJr often used]a when T-Splines go haywire is to export the T-Spline control cage as a .obj and then re-import it converts tinpot a T-Spline.
this may only work, however when you are working with a clear quad mesh, something I would strongly recommend.
if you use n-Gons and t-junctions in your T-Splines it may well back you into a corner. I ma pretty certain two the  .obj format does not not support T-Junctions as the .obj format is a lot older than T-Spline technology.
Message 18 of 49
PhilProcarioJr
@TrippyLighting
"I ma pretty certain two the  .obj format does not not support T-Junctions as the .obj format is a lot older than T-Spline technology."
The .obj file format supports T-Junctions and N-Gons just fine, it's Fusion that can't use them for T-Spline conversion.......
@Anonymous
There is no smooth tool in Fusion T-Splines....
In the area of your screenshot just make the faces quads and you will have fixed your model.
Phil Procario Jr.
Message 19 of 49
TrippyLighting
@PhilProcarioJr I stand corrected 😉
@Anonymous you should really rough out your shape completely before adding detail to it. One ting to look for is proper edge flow. Watch modeling videos for subdivision Surface modeling e.g. Modo, Blender, 3DS Max, Mays, Cinema D. This will provide you wit a much better idea how to model with T-Splines and is directly applicable!
Message 20 of 49
Thanks to all supporting this. You guys helped me to make a step forward. Anyway, I do not want to close this, as this is kinda: Do it 100% right, then you may not run into issues. As a user, I would like to able to fix such things more easily (also called UX .-) )
