Sweeping
Sweeping
Sweeping
i have problems with sweeping. I can't sweep this - check the photo. Can anybody advice please.
Thank you,
mina
Hope I can give some work advice 🙂
I was tried it and I can use the sweep tools
I give you some image when my sweep is work
1. I think you need to give some space between profile and path/rail such as in my image
2. Make sure your path/rail is smooth
Sketch
Look at the red circle
Give some space between profile and path/rail
Select profile, rail, path
That's it, hope it works!
By the way, can you help me with "Like" button for the posts below:
1. https://fusion360.autodesk.com/projects/kujang
2. https://fusion360.autodesk.com/projects/akik-indonesian-gemstone
I am participating in autodesk fusion 360 competition in Indonesia. Thank you very much!
Hello, your help will be very welcome. I don't understand what do you mean by give some space between profile and path rail - to be smooth.
If you want i can send you ipt.file and maybe you can redo my sketch if something is wrong.
All the best
And another question, for sweeping, is it necessary for the end of the profile to be open and not a close spline like?
Thank you
michallach81
About this space between path and edge of profile, you need to give more explanation to that advice, or it will be misleading. In some circumstances it may be valuable, but in most of cases I don't see reasons to do that.
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
michallach81
One more thing I've noticed that you've said something about ipt. file, this forum is for Fusion users.
Michał Lach
Designer
co-author
OMG.....sorry, my mistake Smiley Frustrated
and thank you
all the best
