Sweep Error
So, we are trying to model a Vertical axis Wind Turbine a height of 600 and Diameter of 700mm. The airfoil used is NACA0018. the helix angle is 90. In my file i have made a helix line and a plane on its path on purpose, this is because i was the NACA0018 swept in a way where it is perpendicular to the helix line at every point, not parallel. When i do try to sweep the airfoil, i end up getting multiple faces on the body which is not needed as for analysis this causes an issue. Kindly help in resolving my issue. Find the attached f3d file below and a quick response will be highly appreciated.
