Sweep error: Cannot make sweep enclosure for closed path.
Hi! I am Michael from India. I am beginner in Autodesk Fusion 360. Above attached is an image of the error that i am facing. This error pops up while performing the sweep action. Kindly revert back as to how to resolve this issue. Thanks in advance.
Hi! community the error is resolved. Thanks in advance.
TrippyLighting
The sweep tool can be a bit sensitive in times, ad I'd not use it in this case as there is an easier more stable way to get you the surface you want.
The spline that you use to trim these surfaces can be extruded to also be a surface and then you can simply trim that surface and are left with the warped ring surface you need to fill the gap.
