Hi everyone,
I've been having a lot of success using Fusion 360 with my desktop CNC machine. I worked out some inlay stuff (see the CAM forum if curious) but now I'm having trouble with offsetting an imported SVG. I typically offset my sketches .3mm to create the inlay.
I've watched videos and understand that you can only scale once you've stopped the sketch. But I can only offset anything while the sketch is active. That's not an issue.
My difficulty is when I offset anything from the SVG. I can generate the offset with no difficulty, but Fusion won't recognize that offset as a new profile. It still only recognizes the original SVG profile. Even when I copy the offset and paste it in a new sketch, Fusion won't recognize it as a profile, even though when I run sketch checker, it tells me I have no open loops.
Am I missing something?
