SVG import problem
SVG import problem
SVG import problem
I have a BMP I saved in Inkscape as a SVG so I could set-up to engrave it, when I import the SVG into F360 says the file is empty.
What's the trick here?
Please let me know any further details needed to help find a solution here.
One of the biggest problems I have with inkscape is that when I import SVG from it...they are always real small.
Try making the scale factor when importing to Fusion to something like 20 or 30 to see if that might be the problem first.  Make sure you did a trace bitmap function before saving as an SVG too.
Otherwise I'd try to make sure you convert object or strokes to path.
