- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello Community,
I have imported a SVG file which i've transformed from a pdf file and have imported into fusion for a project, I would like to CNC this artwork later but I need fusion to recognize it as a body which I can potentially push/pull.
I import the SVG directly into an existing sketch and then I get warning signs saying;
I try to find gaps where things are not connected but can't find any, and have seen in other forums a trick to simply draw a line through the middle to find. How do I fix this?
Thank you
