Survey: What tools are in your toolbox?
TMC.Engineering
Message 1 of 11
TMC.Engineering
One of the great things about this forum and fusion to me is how many people have different perspectives, experiences and workflows to achieve goals.  The people often share what works well for them and other tools they use with fusion to get the best solution they can.  I am curious what tools you have in your toolbox related to Fusion?
Here are my tools.... so far...
Fusion 360:                Primary CAD, Primary CAM
Geomagic Design:      Sheet metal and Drawings
CorelDraw:                 Graphic Arts, Laser cutting
David 3d:                   3D scanning
Instant Meshes:         Quad Mesh Conversion
Mecway:                    FEA Simulation:
Calculix:                     FEA solver to expand mecway capibilities
VcarvePro:                 cnc signs.
What do you use?
Timm
Engineer, Maker
System: Aorus X3 Plus V3, Windows 10
Plymouth Michigan, USA
Owner TMC Engineering
Replies (10)
Message 2 of 11
PhilProcarioJr
@TMC.Engineering
Fusion 360: Currently my primary CAD/CAM tool
Zbrush: For sculpting, Remeshing and Normal Map, Cavity Map and AO Map creation
Topogun: Remeshing and creating new comforming Meshes for CAD accuracy
Maya: My main tool for NURBS, Sub-D and polygon modeling.
Lightwave: My main tool for Animations
Substance Designer with IRAY: For creation of materials and rendering
Substance Painter: For painting materials on models
Quixel Suite 2: For Normal Map, Cavity Map and AO Map creation
Photoshop: Image Map editing
Inkscape: For SVG creation
Bitmap2Material: For creating Relief Maps
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 3 of 11
TMC.Engineering
@TrippyLighting@HughesTooling@cekuhnen
I would be curious to know what software tools you guys use in addition to fusion.
Timm
Engineer, Maker
Message 4 of 11
TrippyLighting
  • I've been using Alibre/Geomagic Design prior to Fusion 360 but have not really touched it since I've started working with Fusion 360.
  • Blender for subdivision modeling and form exploration and mesh creation for T-Splines.
  • Indigo Renderer for truly photorealistic rendering and lighting analysis.
  • Inkscape for vector graphics logos etc.
  • Cadsoft Eagle (or shall we say Autodesk Eagle ?) and Altium CircuitMaker for PCB development.
  • Eclipse Arduino IDE ( called Sloeber)
  • GIMP and Pixelmator for general image editing.
  • InstantMeshes & Meshmixer for the usual stuff.
Message 5 of 11
cekuhnen
@TMC.Engineering
Fusion 360
Parametric Modeling
Sub-D and flat polygon to NURBS (T-Splines and Base Feature)
CNC
Flow:
Air tunnel software for our student projects in trans and drones
Blender:
Rapid concept ideation modeling
Sub-D and generative strutcure modeling
Digital Clay sculpting
Product - process animation
Rendering with Cycles
Posing human figures into needed positions
With many add-ons for architecture Grasshopper like generative modeling and such
MakeHuman:
Human figure creation
ReMake:
Photobased object 3D digitizing
InstantMesh:
Remeshing scan data into quad mesh
MOI 3D: Lightweight Rhino replacement
NURBS 2 mesh uv unwrapping
Affinity Photo and Design:
Replacement for Adobe Photoshop and Illustrator
Gravit.io:
Web based Macromedia Replacement for Vector work.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Message 6 of 11
TrippyLighting
@cekuhnen wrote:
Blender:
Sverchok ?
Message 7 of 11
cekuhnen
@TrippyLighting Yes and animate all. Both have a different approach and concept.
Claas Kuhnen
Message 8 of 11
TheCADWhisperer
In addition to Fusion 360
Inventor
SolidWorks
Creo
Meshmixer
AutoCAD
Message 9 of 11
cekuhnen
@TMC.Engineering
I forgot:
Thea Render:
For interior design renderings and such
- since I cannot stand Keyshot hahaha.
I also teach Alias and Maya while professionally I do not use both since I do not have a commercial license for them.
Claas Kuhnen
Message 10 of 11
TMC.Engineering
@cekuhnen you mention cycles and thea render.  what about thea works different/better for interior design?
Timm
Engineer, Maker
Message 11 of 11
cekuhnen
@TMC.Engineering
The render engine Thea uses and the render modes offer in interior views faster results
while Cycles while free struggles with noise in interior spaces. Sure if you have 4 NVIDIA GPU cards
Cycles in interior space is fine yet so will Thea be.
Thea can make use of CPU and GPU at once plus you can set-up a small farm. You can even load
Thea onto Pie PCs and use the GPUs there. The Pie's are cheap and with many you can quickly
stack up a nice GPU farm that is also low in energy consumption.
Overall I think Thea for product and architecture renderings is vastly underpriced. The only advantage I see in Keyshot is the native ability to read CAD files.
Altair recently also purchased them but I cannot assume that this will have an impact on Thea plug=in for Fusion 360.
Claas Kuhnen
