Surface patching
Surface patching
neilvdm
Surface patching
neilvdm
Can somebody please help me as to why I am not able to patch the top section of this body? I was able to patch the bottom layer, but getting errors with the top.
Fusion does the calculations, but when I click on OK is when I get the error
link to the file
Thank you in advance
jhackney1972
When you have a situation like this, I always restore to creating a new edge, via a sketch, to create the desire patch.  When I did this I found the error in the joining edges at the location shown below.  I completed the sketch, using a coincident between the two points, added the patch, stitched to all together and you have your solid.  You modified model is attached by a different name.
John Hackney, Retired
laughingcreek
I think I found the same spot. fixed it a little differently using a boundary fill after trimming a bit our see the attached-
jhackney1972
There are so many ways to skin the cat!  I scanned the edges for awhile but had to turn to a sketch using the "divide and conquer method to find the break.  My eyes are getting to old to follow all those complicated edges.  I like your more direct method.
neilvdm
John, you a star, thank you very MUCH.
so I learn more!
neilvdm
Same to you! thank you. I spend almost 4 hours try to figure this out, but I suppose if I didnt know what to look for, it could have taken for ever 😀
neilvdm
Thank you guys again!
10 minutes later ..
