Surface patch modeling, Pinching/uneven
2 REPLIES 2
alex.martin.watson
183 Views, 2 Replies
I am trying to create a smooth organic shape. I have created a wire frame that's shape cannot be changed much due to design requirements. I then used the surface patch tool to patch all the edges. All connections on the wire frame are tangent to each other and I have made all surfaces follow curvature and/or be tangent to other surfaces.
With all this, I cannot find a way to get rid of the pinching/sharply uneven surfaces at the corners of the surfaces.
Does anyone have any ideas on how I could go about smoothing these all out?
I've also attached fusion 360 file as it may be easier to see what's wrong from there.
Any help would be greatly appreciated 🙂
2 REPLIES 2
Try Loft, I used the outline, to the top centre point, with 4 quadrant rails.
The short rails are not helping due to their own shape.
The outline could do with some work here.
Might help......
That's done it! Thank you 🙂
I had not thought of creating a loft to a single point before, so thank you for the new technique.
Technology Administrators
