Surface extend problems maybe causing Boundary Fill failure
peterg7X5LU
peterg7X5LU
When I try to extend the below surfaces using the Natural option, they fail, leading me to select the Tangent option instead:
But the problem with selecting Tangent is that it then seems to cause lines on the extended surfaces, which I think later leads to a boundary fill failure:
I've attached the file, and would appreciate it if somebody would take a look and show me how to fix please..  The 8 extensions I performed are immediately before the Boundary Fill in the timeline.
TrippyLighting
I am not entie3ly sure what you are designing, but I would not approach such an object the way you do.
For example, there would be no 3D sketches whatsoever.
I would also make sure the curvature of the curves that I use to create surfaces with are smooth. The latter clearly isn't the case in your design:
I would also build this from surfaces that are overbuilt from the beginning, so there's no need to extend surfaces.
peterg7X5LU
I do not know how those unsmooth red curves occurred.  To draw the vertical curves along the z-axis I just drew a fit-point spline.
I will try and overbuild the surfaces like you suggest.
TrippyLighting
Have you considered using T-Splines for this?
peterg7X5LU
I tried using Control Point Splines for my curves and the surface creation and boundary fill works much better...
Thanks for the pointer.  Design progress has increased greatly considering I have a day job that is not design-related!
