Surface continuity
Surface continuity
alandmarino
Surface continuity
alandmarino
Hi, could someone please help me with this. When using the loft command with smooth option activated, only one of the surface edges are both surface and edge continuous. Is there an option i'm missing?
Image attached.
Thank you!
Alan
innovatenate
Autodesk Support
Autodesk Support
Can you share the Fusion design?
Does it help if you modify the tangency weight?
Nathan Chandler
Principal Specialist
alandmarino
Hi Nathan, thanks for the reply.
Yes, tengency weight affects surface smoothness but one of the two edges are still not continuous.
Here's the model: http://a360.co/29j5wa8
Thanks!!
Alan.
innovatenate
Autodesk Support
Autodesk Support
I'm having some difficulty with the public share link. Do you mind posting the archive file?
I was curious if a Zebra Analysis shows if the surfaces are curvature continuous...
Thanks in advance!
Nathan Chandler
alandmarino
here a new screenshot and 3d model
Thank you!
Alan.
innovatenate
Autodesk Support
Autodesk Support
If you add some guide rails to the model you can get a bit more control over the edge. Check out the below screencast for more detail:
Nathan Chandler
alandmarino
Nathan, thank you very very much. Your solution works fine.
However, it would be nice for future versions to fix this issue as is in other software packages. Maybe i should post this as a suggestion.
Thank you again!!!
Alan.
