Announcements
We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Suppress All Except Selected
volodymyr.iaroshenko
hello everyone.
I have a question related to the drawing module. Is it possible to adjust the operation of the "Suppress All Except Selected" function so that the new components that I add in the assembly and which are at the same level in the browser as the component / components that are selected from the menu as "Suppress All Except Selected" do not become visible in the drawing ? Perhaps I did not explain it clearly, I think from the screencast it will be more clear to the problem. Perhaps I'm doing something wrong, then I ask you to tell me what to do in such a situation, because assemblies can be large and for several dozen sheets of drawings of individual components, and when I add such one component to the same level in the browser, I have to turn off the visibility on each sheet where it shouldn't be.
Hope for help.
https://autode.sk/3CcOHLn
thanks
ClintBrown3D
Hi @volodymyr.iaroshenko
The short answer is no. The way it works out of the box, is as a result of user research that was done some time back when we introduced this feature. We may consider a project to look at this again as a future project.
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
Thanks for the answer. After several attempts to understand the logic of work, I noticed that "suppress all except selected" works correctly only at the first level of the assembly, and when adding new components to this level, they are not displayed in the drawing of one selected component in the drawing. But in all subassemblies, when you add new components, they are also added to the individual selected drawing components. Still, it seems to me that this should work the same at every level of assemblies / subassemblies.
