I agree that cosmetic edge fillets are generally better added as 3D features.
But I don't think that means sketch fillets are inherently an inadvisable workflow.
There are plenty of cases where the radius is part of the defining 2D geometry rather than an edge treatment — for example guide rails, slots, tracks, extruded profiles, laser-cut parts, sweep paths, or master sketches that drive several downstream features.
In a guide rail, for example, the radius may define the actual functional path or clearance. In that case I would explicitly want the radius parametrically defined in the sketch, not added later to the resulting solid.
So I think the distinction is more:
Edge treatment → 3D fillet
Profile/design geometry → sketch fillet can be entirely appropriate
And that's why I still think it is reasonable to ask why Center Rectangle and Sketch Fillet, both native sketch tools, interact the way they currently do.
@kacper.suchomski schrieb:
Well, officially, this is a very inadvisable workflow.
I also want to address something separate, because this is now the second time this has happened in this thread.
Instead of addressing the technical question itself, you have repeatedly shifted the discussion toward your personal assessment of how I should model my parts. Advice and alternative workflows can of course be useful, but they should not replace an answer to the actual technical issue being discussed.
Your account is marked as Mentor and Expert Elite, which gives your responses additional authority within the community. I therefore think it is particularly important to distinguish between an actual Fusion limitation, an Autodesk-recommended workflow, and a personal modelling preference.
I have reported my concerns about this interaction to Autodesk.
