Suddenly cannot edit sketches
ea425019
ea425019
So for this one, I am now not able to edit sketches, double clicking dimensions to change them does nothing?
My interest was in "Handle" slot, but other components seem to fail too.
Update:  Now I can select "dimension" and take over an old dimension to modify it. Yet the common technique of just clicking a dimension to change it is gone, which interests me, as it was fine before something changed.
jeff_strater
hmm... it seems to work OK for me.  Am I doing something differently than you are?
Jeff Strater
Engineering Director
ea425019
So there is an issue at my end I suppose.  If I select the dimension it does not open, must be preceded by using the Dimension Tool.  This is new, and different than F360 prior weeks, or Inventor, etc.  Screencast should show below.
 <iframe width="640" height="620" src="https://screencast.autodesk.com/Embed/Timeline/e39a927d-0b4d-4b08-832b-563a2b0ef4ea" frameborder="0" allowfullscreen webkitallowfullscreen></iframe>
TheCADWhisperer
Are Dimensions enabled in your Selection Filters?
