Thank you for quick response. I deduced a couple of local files were under your local cache folder (C:\Users\<User>\AppData\Local\Autodesk\Autodesk Fusion 360\9SVJMGU6MEBH\PLM360Cache\a360proue29e5373.autodeskplm360.net/1/)
(User = eugene)
dfssfsd.f3d
Eugene Knife Repaired v24.f3d
Eugene Knife Repaired.f3d
portable table and seat.f3d
(User = cekuhnen)
bad portable table.f3d
bad portable table-V8.f3d
Eugene Knife Repaired Claas FIX.f3d
Untitled.f3d
work pull.f3d
Unfortunately the log files you run into issues didn't get included in zip files. I cannot know which file was problematic?
Please go to your PLM360Cache folder (C:\Users\<User>\AppData\Local\Autodesk\Autodesk Fusion 360\9SVJMGU6MEBH\PLM360Cache\a360proue29e5373.autodeskplm360.net/1/). You would see some files which extension are .f3d. Here are all local cache in your machine. Please copy that one what you want and rename it and upload to your project. Please open it in Fusion and see if all changes you did were restored?
An example of cache file: "Eugene Knife Repaired Claas FIX.6195f662-7f5f-47b1-ae4a-41b9ace3c474.f3d" -> rename as "Eugene Knife Repaired Claas FIX.f3d" -> upload to your project -> open in Fusion 360.
Also, please go to the folder(C:\Users\<User>\AppData\Local\Autodesk\Autodesk Fusion 360\9SVJMGU6MEBH\) and find all log files like "AppLogFilexxxxxxxxxxxxxx.log" and send them to me for analysis. I would like to find out root cause why your changes were lost.
Marshal
Marshal Tu
Fusion Developer
