Stuck in lampshade step by step tutorial
This widget could not be displayed.
So im following 1 of the 4 tutorials they have on how to learn different operations. Im right now doing the one were you add a lamp switch to the lamp as as a movable joint.
I have made the neck and switch in to 2 components and then chosen the neck as ground and the switch as moving along the axis. However in the next step I cant seem to get the switch to move. I select the neck as target body and the switch as toold body, set operation to cut and enable keep tools and then click ok. but when im then suppose to get the switch to move it will not. I can select it but not move it. In the tutorial there is a small circle indocating you can move it but that usually doesnt just happens with the select tool so I dont know where in the process i went wrong. I tried to right click and move but that didnt work so somehow the components are probably set up incorrectly. I have redone it a couple of times though and im not getting it to work so if someone knows please let me know, im sure its an easy thing im missing.
joel.palioca
Apologies for the inconvience, to get things working correctly for this tutorial what you can do is disable contact sets prior to the move.  See the image below on how to turn off contact sets.
We have plans to get this fix in one of the upcoming updates to resolve any further issues.
Cheers,
[Joel Palioca]
[Software QA Engineer]
Joel(dot)Palioca(at)autodesk(dot)com
Thank you I will try this
