Stuck in Conversion Loop
I was converting a T-Spline and running into errors.  I resolved the errors, but now when I convert it, my original T-Spline has been deleted - along with all other T-Splines.  It converts ALL my T-Splines and deletes them.
I'm caught in a loop because when I open the file - it states that I'm going to be dropped into the "Create Form Environment".  When I hit "Finish Form" so that I can do something else - IT CONVERTS EVERYTHING AGAIN.
I can't do anything but continue sculpting.  This can't be by design.
I've attached the file.  thanks,
bespenship
Hi David,
This looks like the same model you posted earlier that I responded to a bit ago (Invalid t-spine body conversion - autodesk help).  If that doesn't answer your question regarding where your T-splines bodies are, can you contact me directly (brent DOT espenship AT autodesk DOT com) so I can work with you to get you back up and running or understand what's wrong with Fusion?
Brent Espenship
Fusion 360 Quality
Macbook Pro retina - MacOS X 10.11.5 (main)
WIndows 7 Notebook
