stuck in construction
Hello folks!
I'm stuck in SCULPT, i have a file and i imported a file in dxf in it, it was in one "block" so i converted it into multiples parts of bodys. OK
Then when i select on body, ils composed of a multiple polygons with lines and surfaces, but no thickness.
I have tried to extrude it to give it some depth ' in "MODEL" mod but it doesnt work due to the mass of polygons. OK
So my question is : is it possible to cut a solid, made in MODEL mod, with the body? So the solid can be shaped as the body made of polygons?
Im french, so sorry for my very bad English, but i do my best to be understood :)!
Thank you a lot for your advices!
TrippyLighting
Would it be possible for yo to share your file ?
You should be to export it as a.f3d file and attach it
Hello, thank you !
So down below a smart view of what a try to do: i have a car part but only composed of polygons, and i would like to give it some depth. but due to the construction and the complexity ..project.png
patrick.emin
Bonjour, pour votre information, nous avons un forum en français  à Fusion 360 - Français - Autodesk Community
Patrick Emin animateur de la communauté francophone
Vous avez trouvé un message utile? Alors donnez un "J'aime" à ce message!
Votre question a eu une réponse satisfaisante? Voulez vous avoir l'amabilité de cliquer sur le bouton
 APPROUVER LA SOLUTION  en bas de la réponse qui apporte une solution?
Signez notre Livre d'Or
