Struggling with meshmixer unwrap of simple surfaces.
Tulkas33
Message 1 of 16
Tulkas33
I am trying to design a tent and unwrap surfaces in meshmixer to create patterns for cutting and sewing. I feel like I am following video tutorials step by step, but I am getting unexpected results. Meshmixer either flattens the shape to something asymmetrical (This may have something to do with the save as mesh in fusion, since they don't look symmetrical there either, even though I believe the object to be symmetrical), creates an odd loop or kink in the flattened shape, or refuses to flatten at all. In some cases, it appears to complete the flatten but the template is not visible. I would really appreciate any help in understanding what is wrong with my workflow and why the meshes I'm exporting don't appear even.
Accepted solutions (3)
Replies (15)
Message 2 of 16
wersy
Single curved surfaces can be unwrapped in Fusion.
Message 3 of 16
TheCADWhisperer
Need a planar face in Fusion.
(It can be tiny - I usually create larger and then change the size after the Flat Pattern has been generated.)
Message 4 of 16
TrippyLighting
To elaborate on @wersy's post, this object can be unfolded if you employ a sheet metal workflow.
Unfortunately we still cannot flatten/unfold even the simplest surfaces without using a sheet metal workflow.
Message 5 of 16
hfcandrew
Your mesh density is probably too low and/or non-uniform with sliver triangles.
Read/watch here: https://forums.autodesk.com/t5/fusion-design-validate-document/twisting-rectangle-t...
Message 6 of 16
wersy
To be absolutely sure that the surface is only simply bent, I used extrusion instead of loft.
However, there is still a problem.
Message 7 of 16
TrippyLighting
Extend the surface with the tangent option (default is "normal") and then thicken. Then it flat patterns fine.
Message 8 of 16
wersy
Thank You.
But there is still the same problem.
Message 9 of 16
TrippyLighting
I might have misunderstood what the problem is 😉
IN the viewport It doesn't look like there are sketch objects created for the flat pattern. However, when you export it as a .dxf file and open that, there is actually a flat pattern present.
Message 10 of 16
wersy
How can I export as dxf if I have no sketch?
Can you please make a video?
Message 11 of 16
TheCADWhisperer
Flat Pattern
Start new sketch on the face.
P for Project and select the face.
Right click on the sketch in the browser and Save as dxf
Message 12 of 16
TrippyLighting
The flat pattern can be exported to a DXF file without the need to create a sketch and projections YMMV:
Message 13 of 16
wersy
Thanks @TrippyLighting and @TheCADWhisperer
Now I got it. I must creat a sketch before the solid flips back.
But why does it bend back again?
Message 14 of 16
wersy
No problem for the other part, but it need to be a separate component.
Edit
Imported DXFs, copied, mirrored, moved.
Message 15 of 16
TrippyLighting
A flat pattern is a flat pattern for manufacturing purposes. It isn't a modeling tool! Hence the bent object "flips back" when you finish the flat pattern.
If you need to flatten the object to add / change geometry, then use unfold, modify the geometry, followed by a re-fold.
Message 16 of 16
wersy
As I have never worked with sheet metal before, I also wanted to try it out on a printed model.
In order for it to be glued, it needs support.
We have left some comments.
So, if it has helped you, please mark the helped comments as solved.
