Struggling with applying fillets to patterned component
dishwashingcerberus42
Observer Observer
Observer
Observer
I am currently working on a parametric design for a simple tray comprised of a variable number of small compartments that are copied using the rectangle pattern feature. I want the outer four corners of the tray to be filleted, without having to specify which specific edges; as the number of compartments expand, I want the fillets to adjust dynamically. Currently in order to achieve this, I had to apply the fillet to the single compartment that is being patterned. Unfortunately, this is resulting in a divot on the seams between compartments.
I'm a relative noob to CAD in general and Fusion. I'm sure there is a way to do this that is elegant and avoids the issue I am having, but I'm struggling to find it. Any help is appreciated.
jhackney1972
You are approaching the problem incorrectly.  You need to create the partition box and then add the corner radii at the end.  I have attached a sample partition box to allow you to see what I mean.  Modify the partition table values in the Red Box and see.
John Hackney, Retired
Observer
Observer
Thank you very much! I figured I was going about it bass ackwards. Your solution is great.
