Strange F360 Behavior with Cut&Paste
holger_t
holger_t
Hi F360-Team, hi community,
I have built a component which contains sub components. When I cut and paste the parent component and move the new component to another place anything seems to be okay. When I confirm the movement with OK, one of the sub components moves to a place which is not the same as it was before I clicked OK.
The same happens when I built a rigid group (I know this makes no sense) of the sub components as well as using the pattern functionality.
Maybe some have a little tipp for me.
http://autode.sk/1qjXAxm
Best reagards,
  Holger
jakefowler
Hi Holger,
Apologies for the delay in getting back about this, and really sorry that you're hitting this issue. Are you able to share the design so we can take a look at what's going wrong here?
You can post the file/link here, or drop me an email at jake (dot) fowler (at) autodesk (dot) com.
Jake
Jake Fowler
Principal Experience Designer
Fusion 360
