Stop Joint rotation
Firstly I'm mostly a Solidworks user and been a Fusion 360 user mostly to create one off parts for my 3D printer or Router. I'm working on what should be very simple. I have a frame with a series of holes for tubes to go through. The holes are offset from each side creating an angle.
Now the tubes are made of a rigid component and I have a sketch point to set the origin. I've tried to use a rigid joint but then I can't the tubes to follow the angle. I've tried a slider but again the tubes don't follow the axis. I've tried a ball joint and limited rotation and it seems to work, however if I were to make the frame longer or shorter the angle will change.
Right now I'm using a contact sent which limited the rotation but it still moves.
How do I get the joint to follow another point?
