STL
STL
STL
Hello well it gets worse.just tried to save my drawing to a stl for mat .but o no I have to use a defined mesher.or try to put it in the one I want to use =prusa3D slic3r MR2.why can I not just save the stl file?
zaaephod
If you click 'make' at the top of the screen, select '3d print', then select the model you want to export, you'll get the option to save the model as an STL.
Edit: You'll need to un-check 'send to 3d print utility' first.
Hope that helps,
Z
daniel_lyall
Right click on the body and select save as stl
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
I created a 50 mm square by 20 mm high open box, used Make 3D Print, and Export a 4 kb STL file that will not print. I know from other experience the file should be several megabytes to print. What am I doing wrong?
Robert
HughesTooling
@Anonymous We'll need more info. How about some pictures or better still export your design as an f3d file and attach.
Mark
Mark Hughes
Owner, Hughes Tooling
