STL to Solid
STL to Solid
22lockwood
Message 1 of 12
STL to Solid
22lockwood
Hi I am trying to convert a STL to solid using Fusion 360 here is the file that I am trying to convert. I have followed many tutorials online and none of them have worked. Could some one tell me what I am doing wrong. Here is what the object looks like when I try and convert it. Please advise.
Replies (11)
Message 2 of 12
abhinav_singh
I fired up Fusion360 > File > Upload > Selected the STL file provided by you > waited for few seconds > import seems to be working fine for me.
Is this how it was supposed to look?
Abhinav Singh
Product Owner
Message 3 of 12
22lockwood
Message 4 of 12
22lockwood
Yes! I can get that far but I need to make it a STEP file so a mesh wont work for this application.
Message 5 of 12
jhackney1972
Attached is the STEP file I get.  The STL has some errors so the repair operation may have changed to model, check it carefully.  By the way, the STEP file is large and takes a bit of time to open.  If fact it is too large to attach.  I placed it in my Dropbox and you can retrieve it from there with this link.
John Hackney, Retired
Message 6 of 12
jhackney1972
Did the STEP work for you? If so, please mark those solutions by pressing the "Accept Solution" icon. This will do three things. It will remove the question from the active list, it will allow others to find the answer to a similar question and last it will acknowledge the effort and time of the poster(s) supplying an answer.
If you need further help, please ask giving further details of your needs.
Message 7 of 12
TrippyLighting
If you've tried to convert this using the prismatic conversion, the  that will unlikely result in the desired prismatic BRep results. This mesh is missing quite a few faces.
What is it you want to do with the end result ?
Message 8 of 12
22lockwood
I just need a solid STEP file. I need to make it a solid object so I can edit it in the future.
Message 9 of 12
22lockwood
Yes I have been able to do this but I unfortunately need it to be smooth
Message 10 of 12
TheCADWhisperer
I would use the imported stl mess, err I mean mesh only as reference in creating proper geometry from scratch.
Fortunately this part geometry is relatively simple.
Message 11 of 12
22lockwood
I agree, there are many reliefs in the end of this part that are quite hard to design but the rest is very simple.
Message 12 of 12
TheCADWhisperer
I used the make tooling like this.
The biggest tip I can give you is to walk out to the shop floor and see how it is manufactured. No special processes.
If you don’t have that advantage of seeing actual manufacture of the tool (not use of the tool - actual making of the tool) you will be at a disadvantage. It is Extrudes and Revolves. Some of the Revolves are made at angles. Attach the *.f3d file of your progress here for diagnosis at each and every step. Again, do it like you would make it on the shop floor.
