stl to invisible brep
etfrench
Mentor Mentor
etfrench
Is this the expected behaviour when converting stls to breps?
Screencast: https://knowledge.autodesk.com/community/screencast/17bfe239-5b89-46c1-8691-d5564bd4e980
Original model: http://www.thingiverse.com/thing:675092
ETFrench
masa.minohara
Hi @etfrench,
Thank you for reporting the issue. No, that is not an expected behavior. I have logged the issue in the internal system so the development team will investigate it for the root cause (FUS-26509). Could you try using "Insert Mesh" command instead of uploading to the Project? That worked for me.
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
