STL File Will NOT Save in Fusion 360
 Hey guys,
Everytime I try to save my project as aSTL file it would give me the following error.
Error: STL Translator failed to export data
Error: Autodesk Translation Services failed to translate the current document to stl file!
How do I fix this?
Thanks in Advance
brianrepp
Moved to Design & Documentation forum for better visibility
Hi Elliott, if possible, it would be great if you could export your model in Fusion as .f3d and upload it to this thread.  One alternative route you could try is to go to Create > Create Base Feature, then Modify > Mesh > Brep to Mesh and select the body to convert.  After that, you can select and then right click the mesh to save as .stl or now the additional option of .obj (both of these can be opened and edited in Meshmixer and the like.
Good luck!
Jesse
