STL file opened in Tinkercad differs from same Mesh imported into Fusion 360
Whenever I import an STL as a Mesh into Fusion 360 it imports just fine, but when I import that same STL into Tinkercad it has additional artifacts such as blocks added to it. I've attached two pictures of a car. Look at the bottom of the car. The one from Fusion 360 shows a flat bottom of the car. The same STL imported into Tinkercad shows big, square blocks on the bottom of the car.
The only reason I need to open these files in Tinkercad is I need to isolate different parts of them for 3d printing, such as each wheel and tire, and I don't know how to do that in Fusion 360 but I can in Tinkercad. I can split an object in Fusion, but only on a plane. I can't yet "extract" an object like a tire, that's why the need to open files like this in Tinkercad.
Anyone have any ideas why the reason for the additional artifact between the two programs for the same files?
