STL Export of a Fusion 360 model from A360 website doesn't work
robduarte
robduarte
Hi - I'm having trouble exporting a F360 model from A360.
I can go to a different model in a different project, choose Export and see the STL appear in the project afterwards.
With the model that I'm having trouble with, I follow the same process but nothing ever appears in the project. No errors, nothing.
Any ideas?
Rob
Rob Duarte
Associate Professor in Art, Florida State University
Co-Director FSU Facility for Arts Research
http://art.fsu.edu/rob-duarte/
Twitter | YouTube
innovatenate
Autodesk Support
Autodesk Support
Would you mind testing this again? There was a brief window where the translation service was down yesterday for an update. I'm curious if this behavior may be related.
As a work-around solution, you may be able to open the design and use the Save As STL command to get the desired results.
After creation, manually upload the STL file to the Project in A360 Dashboard.
Hope that helps!
Nathan Chandler
Principal Specialist
hi
why has the stl export disapeared????
how are we supposed to export now please?
thank you
innovatenate
Autodesk Support
Autodesk Support
The command should still be there. There may be a limitation with the type of body you are trying to export. Would you mind sharing a public link with me so I can take a closer look at the design?
Please enable the item to be download:
Let me know if you have any questions.
Nathan Chandler
Hello, sorry to resurrect a dead topic.  Can you help me export a .stl?  Here's my public link.  http://a360.co/2atFrJt
Edit, never mind.  I'm using the File > 3D Print command to make an STL in PrintStudio.
