Stitched surfaces don't convert in solid?
inaid
inaid
Hi all,
I stiched many surfaces of complex piece and all of them stiched ok, without problem but the result is not a solid, it is a single surface.
Could you please tell me why it happens?
I attach a capture to see what is the result after stitching.
HughesTooling
If you go to the Patch work space and click Stitch and select the model are there any red lines on the part, if there are you have gaps in the model you'll need to fix.
Mark
Mark Hughes
Owner, Hughes Tooling
