Stepper Motor Pivoting Arm Help
infoS4R27
Observer Observer
infoS4R27
Observer
Observer
Hi,  I'm trying to build a model of this  fuel probe for a flight sim.  The probe need to lift up and down (pivoting on the main pin, joint 1).  I've added the cylindrical joints but how do you make them all stick together at the same time?  All my joints seem to only be connected to themselves?  Thanks!
Drewpan
What you probably need here is a Motion Link to define what happens when you move
one joint that affects the other. It is commonly used for such things as Jack Screws
where the screw rotating makes the joint move up or down. I would imagine that in
this case as the bracket moves forward or back that the arm rotates up or down.
Good luck.
Cheers
Andrew
TheCADWhisperer
@infoS4R27
Do you have original geometry before it was converted to stl?
navya_gelli
Hello, @infoS4R27 ,
Did the information provided by @Drewpan help you and answer your question?
If yes, please click on the "Accept Solution" button on the post(s) that solved your problem. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Navya | Community Manager
Let us know how we did on Trustpilot.
Navya Gelli
